Activity Forums Apple Final Cut Pro Legacy Carbon Copy Cloner…cross posted on OSX
  • Carbon Copy Cloner…cross posted on OSX
    Posted by Rich Rubasch on January 26, 2006 at 3:54 am
    Having some problems cloning an installed OS tiger disc to another SATA drive. The new SATA is in the G5 with the other. I just keep getting a password error but I know it’s right. It just sort of hangs after the password is entered.
    Any tricks here?
    I’ve had mixed results in the past with CCC. Any experts out there? Hidden settings. Any other thoughts?
    Other apps that do the same thing more elegantly?
    Rich Rubasch
    Tilt Media
    Dan Seeger replied 20 years, 7 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    January 26, 2006 at 5:20 am
    Try SuperDuper! I switched after components of CCC seemed to not be supported.
    https://www.shirt-pocket.com/SuperDuper/SuperDuperDescription.html
    Cheers
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Dan Seeger
    January 26, 2006 at 6:21 am
    I replied to your cross-post on OSX. I won’t repeat it all, but basically it was that CCC sets r/o attributes on the copy (or at least it did it to me). An easy fix in Finder (hit ‘info’), but I’ve switched to Intech’s Quickback. (Buy a ADS firewire drive for $60 and you get the $80 set of apps free.) Your problem is not quite that, but I’d check the attributes just in case. Might be cascading error messages.
