Activity Forums Compression Techniques Carbon Coder – Windows Media installation unable execute tasks
  • Carbon Coder – Windows Media installation unable execute tasks
    Posted by Joost Van voorst on December 19, 2008 at 9:13 am
    Crew,
    I have a WIndows Server 2003 installation with Carbon Coder (3.12.0.12960). It is running various tasks including converting voice recordings to MPG, DV to MPG etc. Those are running fine. One of the conversion tasks is creating WMV files but fails every job due to:
    Your Windows Media installation is unable to execute the required tasks.
    Please check your file and/or encoding parameters, or reinstall the Application.
    This is what I tried so far:
    A restart of the service
    A re-install of the application
    A re-install of both the OS and the application
    An installation a new version (3.12.0.12960)
    Any suggestions are welcome.
    We must never be afraid to go too far, for truth lies beyond. – Marcel Proust
    Joost Van voorst replied 17 years, 8 months ago 3 Members · 13 Replies
  • 13 Replies
  • Daniel Low
    December 19, 2008 at 11:23 am
    What settings are you using? What source are you using?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Joost Van voorst
    December 19, 2008 at 2:53 pm
    Source File: varies from AVI, Flash, Mov Etc.
    Target File:
    VIDEO
    1 stream(s) (448 kbps) selected. Click for viewing all streams.
    WM Video Stream 1
    384×216
    Video 16:9 Pix 1:1
    FPS 25
    Video Bitrate 448
    8kf/s
    Image Q 50
    Constrained VBR
    Max kbps 1000
    AUDIO
    1 stream(s) (128 kbps) selected. Click for viewing all streams.
    Audio Stream 1
    Windows Media Audio 9.1
    128 kbps
    KHz 44.1
    Bits 16
    Stereo
    2-pass
  • Daniel Low
    December 20, 2008 at 12:24 am
    1. Never use FLV as source.
    2. When you say ‘8kf/s’ do you mean 8 keyframes per second or…..?
  • Andy Mees
    December 20, 2008 at 9:11 am
    Daniel,
    If one does have FLV as a source are you recommending some form of transcode prior to feeding it into Carbon Coder … or is the “never use” rule meant more as a general avoid at all costs thing?
    Cheers
    Andy
  • Daniel Low
    December 20, 2008 at 10:38 am
    I mean avoid at all costs. VP6 and Sorenson spark are delivery only codecs. Of course if that’s all you’ve got then you don’t have a choice, the quality will usually be rubbish.
  • Andy Mees
    December 21, 2008 at 4:11 am
    thanks for that . yeah, sometimes you just get what you get … CC handles it pretty well but as always Garbage In Garbage Out
  • Joost Van voorst
    December 30, 2008 at 9:35 am
    Crew,
    Thank you for sharing your thoughts. SInce this system is serving a newsroom I don’t have control over the source codecs being fed to the Carbon Coder. Besides that the “to use or not to use FLV” is an entire different discussion. Interesting, but not very valuable to the problem at hand.
    Any suggestions on the phrase:
  • Daniel Low
    December 30, 2008 at 12:59 pm
    You didn’t answer my second question relating to your settings:
  • Joost Van voorst
    December 30, 2008 at 1:21 pm
    Sorry, yes you guessed right. keyframes a second.
  • Daniel Low
    December 30, 2008 at 2:51 pm
    8 keyframes per second is way way to many – you should be inserting a keyframe every 10 seconds, or once every 250 frames if you work in PAL. As you have it, the encoder is trying to set a keyframe every 3 frames.
    It’s quite likely that this is what is causing the problem.
