Activity Forums Adobe After Effects Expressions Car wheel rotation on an angle
  • Car wheel rotation on an angle
    Posted by Ben Tillett on July 23, 2011 at 8:47 am
    Hi, hope someone can help.
    I’ve got a car set up so that the wheels rotate when the car is moved left to right. But I can’t work out how to extend the expression so that the car may move on a diagonal path with the wheels rotating correctly.
    Not sure if I explained that well, but imagine a car in 2D moving up and down the contours of a mountain. So not flat along the x-axis, but diagonally. Is there a way to modify the expression so the wheels rotate correctly?
    I think it has something to do with trig, and working out the hypotenuse dynamically based on the slope/angle of the car and the distance travelled in x and y.
    Roger Maus replied 12 years, 4 months ago 3 Members · 3 Replies
  • Dan Ebberts
    July 24, 2011 at 9:41 pm
    For an irregular path, you’ll probably have to calculate the length of terrain traversed frame by frame. I’d start with something like this:
    accum = 0;
    for (f = timeToFrames(inPoint); f <= timeToFrames(); f++){
    t = framesToTime(f);
    p0 = position.valueAtTime(t-thisComp.frameDuration);
    p1 = position.valueAtTime(t);
    accum += length(p1,p0);
    accum*360/(Math.PI*width)
    Dan
  • Ben Tillett
    July 25, 2011 at 9:34 am
    Dan, thank you so much!!
    After a little tweaking for my particular situation, that worked a dream.
    Thank you sir,
    Ben
  • Roger Maus
    April 26, 2014 at 9:36 pm
    Sorry fo waking up this old lad…. can I make this work in 3D space too? how?
