Activity › Forums › Apple Final Cut Pro Legacy › Caputre Stills from footage
Posted by Joey Williams on June 23, 2009 at 3:42 pmHey there-
I have some footage in FCP, and I’d like to pull some stills from the footage. What is the best way to do this?
JW
TOAD ARRAY
https://toadarray.comJoey Williams replied 17 years, 2 months ago 4 Members · 7 Replies -
Rafael Amador
June 23, 2009 at 4:15 pmApply a De-interlace filter to the clip (if the footage is not progressive), Modify> Make Freeze Frame (or mark In-OUT in the same frame) and Export QT Conversion> Image Sequence.
Select the still format that you need.
Cheers,
Rafael -
David Bogie
June 23, 2009 at 4:16 pmStart with the manual for more details.
Export>Quicktime conversion>still image.
Your predictable followup to this is, “Those suck. How do I get better quality stills?” and our response is, “You can’t. You are limited to the resolution of your video camera which is probably less than 500×800 pixels and yoru shutter speed which was probably 1/60th second and your ability to understand and cope with field interlacing.”
bogiesan
Joey Williams
June 23, 2009 at 5:48 pm -
Joey Williams
June 23, 2009 at 8:10 pmOnly problem right now is that it keeps exporting the image in a 4:3 aspect ratio, and is pressing the 16:9 picture. Any suggestions?
JW
TOAD ARRAY
https://toadarray.com -
John Fishback
June 23, 2009 at 9:20 pmOnce you have your stills you can use this to uprez them.
https://www.benvista.com/main/content/content.php?page=ourproducts§ion=photozoompro_1John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Rafael Amador
June 24, 2009 at 2:07 amWhen you bring your stills to Photoshop and st “Correct for aspect ratio”.
rafael
