Activity › Forums › Apple Final Cut Pro Legacy › Capturing XL-H1 HDV
Capturing XL-H1 HDV
Posted by Hepkat on May 30, 2006 at 5:40 pmCan FCP 5.0 capture HDV footage from an XL-H1?
Hepkat replied 20 years, 3 months ago 2 Members · 2 Replies -
Daniel E
May 30, 2006 at 8:21 pmIt depends on the Frame rate you recorded the HDV in the Canon and the capture method. 5.04 can capture 60i and 30F but not 24F through firewire. If you are using a Kona Card you might be able to come in through the SDI and convert the footage to some other CODEC.
Daniel Epstein
Gold Teleproductions, Inc
New York, NY
http://www.goldtele.com -
Hepkat
May 30, 2006 at 8:46 pmw*h*e*w
Luckily, I shot all 30P and 60i.
Thanks for the info.
-Tom
(hepkat)
