Activity Forums Apple Final Cut Pro Legacy Capturing Without Timecode
  • Capturing Without Timecode
    Posted by Kathy Obrien on April 7, 2010 at 4:06 am
    Please help!
    I filmed an event a few weeks back using miniDV. One of the cameras has 24p and I am finding now that when I play back the tape, there is no timecode….??? I’ve never encountered this! Also, I realize now that I recorded it in LP, which may have caused the weirdness. Regardless, now I am unable to capture in FCP because there is no timecode and it just searches for timecode endlessly. HELP! I tried using the “Non-Controllable Device” option in the capture settings, but it errors out after only a few seconds, saying there’s an issue with the tape…any ideas?
    Kevin Monahan replied 16 years, 5 months ago 3 Members · 4 Replies
  • Peter Brewer
    April 7, 2010 at 4:17 am
    Use DVHSCap. It’s like doing a capture now and captures the footage via FW as a m2t file. Then use either Mpeg Streamclip (free) or my favourite Clipwrap to change it into a MOV file. I have never had an error doing this.
    Peter Brewer
    http://www.indimax.com.au
  • Kathy Obrien
    April 7, 2010 at 4:47 am
    OK, so I downloaded these programs and DVHScap is saying that I do not have a DVHS Device connected. I tried changing the order in which I turn on the camera and open the program, but I can’t seem to get it to detect my camera. Do you know why this may be?
  • Peter Brewer
    April 7, 2010 at 4:57 am
    Are you capturing the footage through a deck or camera? I assumed since it was 24p that it was HDV. Is that correct? If I switch my deck here to DV instead of HDV I get the same message.
    I would guess that the LP is the main issue. I haven’t had to capture footage in LP but I have heard that there can be lots of dropped frames.
    You could try directly copying the LP tape to a SP tape and then capture from that.
    I hope that helps 🙂
    Peter Brewer
  • Kevin Monahan
    April 7, 2010 at 8:22 am
    Try setting your device control settings to “non-controllable device”.
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
