Activity Forums Adobe Premiere Pro capturing without project
  • capturing without project
    Posted by Robert Dulfer on September 13, 2012 at 2:44 pm
    I have several miniDV tapes with various content on each tape. Rather then looking and rewinding tapes time and again to get all content belonging to one topic in one project and other topic in another project, I would like to blindly capture everything onto hard disk and then start sorting.
    I could not find a way how to do that, so what I am doing now is make a “project” for each tape while doing something else. If I notice a brake I will make a new clip name and just continue tape capturing. However, this clutters up the folder with projects also.
    Is there a direct way to blindly capture tape only as avi file or do you always have to go the project route?
    Asus P8Z68-V Pro gen 3; i7-2600k; 16 GB RAM, ASUS-NVIDIA GTX 570, 240 GB SSD as OS and 1 TB WD as data drive, Coolmaster Silencio 550 silent case (I love it). Adobe Production Premiere CS 6
    Robert Dulfer replied 13 years, 11 months ago 3 Members · 3 Replies
  • Chris Tompkins
    September 13, 2012 at 3:11 pm
    I use a “work Area” project for such things, or a scratch project.
    Create a Capture Proj. if you like.
    Load all in.
    Then import clips into the corresponding projects. Just a thought.
    Chris Tompkins
    Video Atlanta LLC
  • Jeff Pulera
    September 13, 2012 at 3:45 pm
    Hi Robert,
    Do you ever use the “Scene Detect” option during capture? This automatically breaks up your clips into individual .avi files at every scene change. Once all your material is captured to the hard drive, you can delete the Premiere Project if you want – the clips will remain on the drive to use as desired later, and you can certainly review and organize them into different folders and such if need be.
    You can then create different projects for different subjects and import/use only the clips you want. Note that within a single project, you CAN create multiple Sequences, or Timelines. So within the single project, you can organize clips in the Bin with folders, and work on several different sequences within that Project if you want.
    Jeff Pulera
    Safe Harbor Computers
  • Robert Dulfer
    September 19, 2012 at 6:10 pm
    Dear Chris and Jeff,
    Thanks for the response. I am a bit away from internet nowadays, so replies can be late. What I did as suggested is just capture it in projects, and in the end move the footage to easy sortable folders and
    deleting everything else.
    As to scene detect, the footage I am capturing was made by amateurs (including myself), so sometimes there is a few minutes unrecorded space between shots and sometimes the rewind-then record goes on top of earlier shots. In the end, I found it easier to just tape-capture and if PP stops because there is empty space, make a new clip name and continue. Sorting I will do once all is on PC and the tapes saved.
