Activity Forums Apple Final Cut Pro Legacy capturing with timecode
  • John Pale
    June 23, 2010 at 4:27 pm
    No.
  • Michal Yaniv
    June 23, 2010 at 5:19 pm
    ok, thanx
    Michal Yaniv
    http://www.avocadofilms.info
  • John Pale
    June 23, 2010 at 5:45 pm
    Best thing to do, until this feature is added, would be to hook up the output of the Char Output of the deck to a monitor while you log.
    Be sure to use the feedback link in FCP if you want this feature.
  • Michal Yaniv
    June 23, 2010 at 7:43 pm
    Hi John,
    thanx again for the info.
    I’ll do my best and meanwhile I’ll do it in the “old fashion way”
    Michal
    Michal Yaniv
  • John Heagy
    June 24, 2010 at 2:05 am
    If you are capturing HD via a Kona card then there is a way.
    With FCP and Log & Capture open, launch the Aja Control Panel and arrange the FCP windows so you can see the Aja Panel. Click the “Timecode” tab in the AJa Panel. When you play the tape you should see code running in the Aja Panel. This assuming the HD deck as embedded TC, I’d be surprised if it didn’t. This will not work with SD.
    John Heagy
