Activity Forums Apple Final Cut Pro Legacy Capturing with Canon XL -H1
  • Capturing with Canon XL -H1
    Posted by Mark Albertin on October 3, 2006 at 2:09 pm
    I’ve shot some footage with a Canon XL-H1 camera and am trying to capture it with FCP 5.04. Set all my presets to HDV but FCP still does not recognize the camera. Do I need a special plug in or does anyone have any suggestions? Thanks.
    C.hanky replied 19 years, 10 months ago 3 Members · 2 Replies
  • Aaron Neitz
    October 3, 2006 at 7:24 pm
    That camera was not supported in 5.04. You need to go to 5.1, and if you shot 24F mode, you need to go to 5.1.2
  • C.hanky
    October 30, 2006 at 1:04 pm
    Capturing HDV with Canon XL-H1 (PAL)
    Disconnect all cables, set the [Playback Std] to [HDV], set the [HD Down-Conv] to [OFF].
    Connect the cables.
    In FCP 5.1.2 set the easy setup to HDV-1080i50.
    After verifying you can capture with it, you can change settings.. (Isn’t really necessary)
    I don’t know if it works with 5.0.4 or 5.1 because I bought 5.1 and updated it to 5.1.2.
    I thought the problem was the software, but it turned out to be the camera.
    Henk
