Activity Forums Avid Media Composer Capturing video numerous time it will abruply stop, PLEASE HELP
  • Kris Anderson
    July 5, 2009 at 2:28 am
    Hi Chris,
    If Avid is stopping repeatedly on digitise then it is quite likely it is encountering timecode breaks on the source tape.
    Go to your ‘settings’ tab (next to ‘bins’ in your project window) then go to ‘Capture’. Once there, select “capture across timecode breaks”. This will allow Avid to re-cue and keep going if it finds a TC break.
    As an aside, as someone who regularly conforms other people’s sequences, it would be helpful to you longer term if you give each TC break a new name. As an example, I use “Tape 01 TC1” and increment to TC2, TC3 and so on for every TC break I find. This is especially helpful when there are multiple instances of the same code on a tape.
    Hope that helps.
