Capturing video in Decklink HD Extreme 3D+ no Picture
Hi
First off let me say that I am new to video capturing so I apologize in advance if I make any rookie mistakes.
So I have a Decklink HD Extreme 3D+ in my computer and have Media Express along with it. What I’m trying to do is record gameplay from an Xbox 360. The problm I’m having is I don’t get any image when I hook it up. I’ll try to list out as much detail as I can so you have all the infomation I do.
I connected the Xbox by HDMI to the back of the Decklink in one of the HDMI ports. I also found out about the Blackmagic Control Pannel option, and chaned the setting there to: “Set input: HDMI video & HDMI Audio”
Then I go to Media Express, go to capture, and it doesn’t show anything. I also tried connecting it to the other HDMI port, but again it doesn’t give any picture.
So then I tried to connect it to Component cables, and chanegd the settings in the Control Pannel to “Component Video & AES/EBU Audio” and the Green cable in the ‘Y – In’ Red cable in the ‘R-Y In’ and Blue cable in the ‘B-Y In’ of the breakout cable. Again no picture (I didn’t connect the audio cables as I was just seeing for the picture)
I then switch to composite cables, plug the Yellow in the ‘Y In’ and the audio in the AES/EBU ones, and switch the settings in the Control Pannel to “Composite Video (Y In) & AES/EBU Audio”, then head back to Media Express, and I get picture.
What I want to do is make it work via HDMI cables and capture at 1080p 60fps (Xbox does 60 frames). My Xbox is PAL and right now on 1080i (I also tried 720p but no picture still). I think it is something I am doing and maybe not putting in the correct settings but I don’t know which to put. Any help would really be appriciated.
