Capturing video from mini dv, some Qs and best practices?
Hi all,
I’m an audiovisual artist, and I’m in the process of researching in order to streamline my workflow for best quality image. Regarding capturing video, I’m using a panasonic pv-gs250 PAL minidv camera. I’m capturing using vegas capture application via firewire, so far so good, 0 dropped frames.Does the vegas project settings affect the way video is captured (for instance interlacing and field order settings)? What are the recommended color correction and level optimization techniques after capturing? What about compression when capturing? I’m almost sure that all my compressed video files will be mjpeg because of quality and performance. Are there any other things i should take into account when capturing video?
Thanks a lot.
