Activity Forums Adobe Premiere Pro Capturing VHS LP tape
  • Capturing VHS LP tape
    Posted by Acacio Ximeno on April 14, 2009 at 2:18 am
    Normaly I capture VHS SP playing it with a Panasonic AG-W1-P, capture via a Canopus ACedvio card installed in my pc. But when the tape is LP there is my big problem.
    I work hard to obtain a solution, but negative.
    I will appreciate any help and thanks in advance.
    Acacio Ximeno
    Acacio Ximeno replied 17 years, 4 months ago 3 Members · 4 Replies
  • David Doty
    April 14, 2009 at 3:09 am
    What is your problem ?
    Pal or NTSC ?
    Editing software used?
  • Todd Roush
    April 14, 2009 at 6:49 am
    Are you saying that your capture card only does 1 hour at a time?
    Ahhh…..good old VHS. Pop it in and record.
    Todd
    Todd Roush
    Dreamscape Digital Media
    Panny DVX-100’s but changing so Sony or Cannon HDV soon.
  • Acacio Ximeno
    April 14, 2009 at 11:31 am
    My exact problem is for example: if the VHS tape is 2 hours when I capture CS4 views it in less time, so I have distortion in the image and in the audio, the audio I fix wery well aplying the effect motion reduce the speed in a 40%, more or less.
    I think the problem is the velocity of the recording, because when you record in a VHS tape in SP mode you can put 2 hours, if you do it in LP you can put 4 hours.
    This also happens in minidv tape, you need to have the video camara that record that tape.Maybe in VHS tape you need also the original recorder.
  • Acacio Ximeno
    April 14, 2009 at 11:34 am
    I do not have the problem 1 hour at a time. Yes they are old VHS tape.
    What you men with “Pop it in and record”? I do not understand.
