Activity Forums Storage & Archiving Capturing VHS, drifting vertical sync
  • Capturing VHS, drifting vertical sync
    Posted by Lauri Ahonen on July 26, 2011 at 1:18 pm
    I’m currently in the process capturing several hundred of VHS archived material as H.264 video. We are using Blackmagic Intensity Pro and Blackmagic H.264 Pro Encoders.
    I would ask for your help with drifting vertical sync when capturing. I suppose that I would need a external sync generator of some sort. What kind of an unit would I require? The video is TBC synced S-Video PAL 576i signal.
    M.D. Lauri Ahonen
    Electronics and video processing enthusiast
    Lauri Ahonen replied 15 years, 1 month ago 1 Member · 1 Reply
  • Lauri Ahonen
    July 28, 2011 at 8:53 pm
    I’m not having the problem with my other capture hardware. The problem must by with the H.264 encoder.
    M.D. Lauri Ahonen
