Activity › Forums › Adobe Premiere Pro › Capturing uncompressed
  • Capturing uncompressed
    Posted by Whaaaaat on October 18, 2007 at 1:33 pm
    I want to capture footage from tape to my comp with the best quality as possible. So i’m thinking can you capture it uncompressed or do i have to stick with the standard dv settings in premiere pro 2.
    Whaaaaat replied 18 years, 11 months ago 3 Members · 5 Replies
  • Harm Millaard
    October 18, 2007 at 1:40 pm
    What camera stores uncompressed that you want to capture from?
  • Whaaaaat
    October 18, 2007 at 2:00 pm
    i use this camera https://www.kieskeurig.nl/product/1D8B5EC9960E3A71C12570F800431D73.htm
    But i’m guessing you’re saying that when i record footage it automatically stores in dv?
  • Blast1
    October 18, 2007 at 5:18 pm
    [whaaaaat] “But i’m guessing you’re saying that when i record footage it automatically stores in dv?”
    You got it! The transfer to the computer is exactly whats on tape with just a ID/data wrapper added so the computer knows what it is, firewire is just a high-speed serial port. making the footage uncompressed increases the size of a DV file also, DV is compressed 5:1 with 4:1:1 quantization of color which is also a form of compression, take the time to do some research and find out what the size and data rate will be for a uncompressed video file, also making uncompressed doesn’t increase the original quality of whats on tape
  • Harm Millaard
    October 18, 2007 at 5:25 pm
    Your camera records compressed in DV format. No sense in uncompressing it. Just use DV type 2.
  • Whaaaaat
    October 19, 2007 at 3:14 pm
    Will do and thnx for info
