Activity Forums Blackmagic Design Capturing to SD from HDV
  • Capturing to SD from HDV
    Posted by Will Macneil on June 19, 2005 at 11:55 am
    Hi, I’ve got a project coming up using a mixture of Digibeta and HDV (shot at HDV.) The final output and transmission are SD. I’m plannig to capture the HDV as SD in the uncompressed codec (either 8 or 10 bit.) We may also use the HDV full size for some graphics work, but that’s independent of the edit. I’m wondering how to get the signal in for capturing. So:
    1. Is it possible to capture the HDV via firewire and transcode it to SD on the fly?
    2. Or can I use the downconverter in the deck and capture via component or SDI?
    3. Is there an SDI output on the HDV decks?
    4. Is there a rs422 control port on the HDV decks?
    Will
    Olivier Jean replied 21 years, 3 months ago 5 Members · 4 Replies
  • Steve Connor
    June 19, 2005 at 4:19 pm
    1. No
    2. Component only
    3. No
    4. No!
    Steve Connor
    Cardinal HD
  • Juan Salvo
    June 19, 2005 at 10:21 pm
    You can set the camera (or also deck i beleive) to downconvert HDV to dv over firewire… the results are quite nice.
  • Brent Melton
    June 20, 2005 at 1:32 am
    I did a little experiment last week and captured HDV as 4:2:2 8bit SD via the component output on the Z1 and the Decklink Express. It looked pretty good. I hope to have a better look at footage later in the week. The downside is that there is now timecode.
    Has anyone else had any experince capturing HDV to SD this way?
  • Olivier Jean
    June 20, 2005 at 11:22 am
    Hey Brent,
    use firewire as deck control that will
    take care of Timecode.
    Regards
    Olivier Jean
    Powermedia Systems
    Sydney Australia
