Activity Forums Apple Final Cut Pro Legacy Capturing Timecode from Sony UVW-1800
  • Capturing Timecode from Sony UVW-1800
    Posted by Buddy Unidas on March 28, 2006 at 10:54 am
    I’m trying to capture from a Sony UVW-1800 to my FCP system. I would normally go through my Sony Analog/DV firewire converter, however I need to capture the timecode as well so I can follow a script with timecode. How do I go about capturing timecode under the “Non-controllable Device” template? Do I need to get an I/O with a black burst input? If so, which card or box can u recommend? Thanks in advance.
    Bud
    Ron James replied 20 years, 5 months ago 6 Members · 12 Replies
  • 12 Replies
  • Lee Berger
    March 28, 2006 at 12:32 pm
    You can only get timcode from the RS-422 port on your 1800. You need a USB to Serial adaptor such as the Keyspan Twin Serial Adapter.
    https://www.keyspan.com/products/usb/USA28x/
    You will also need a DB9 Male to Mini Din 8 Male cable to connect from the Keyspan Adapter to the RS-422 serial control port on your 1800.
    The bonus is that this will allow you to control your 1800 using device control.
  • Bret Williams
    March 28, 2006 at 3:35 pm
    Don’t forget to set a frame offset of -1 in the capture settings. There is a 1 frame delay on the video coming in through the converter, but no delay on the TC coming in through RS-422, so it’s actually 1 frame ahead.
  • Lee Berger
    March 28, 2006 at 3:46 pm
    Good Point! Thanks.
  • Ron James
    March 28, 2006 at 5:27 pm
    Does this offset apply to DV decks, also, like the Sony DSR-40? I can’t *see* any offset with my deck and the Keyspan control. It appears to be dead on.
  • Dean Sensui
    March 28, 2006 at 6:53 pm
    I’m using a Blackmagic Decklink SP card. It also provides deck control, reads timecode, has component in/out, etc.
    Works well and hasn’t given me any trouble.
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Kevin Hedin
    March 28, 2006 at 7:32 pm
    FOR SALE: I have a Keyspan Twin Serial Adapter and a Pipeline Digital Serial Cable to attach to your UVW-1800.
    This is exactly what you need to get TC from your UVW-1800 deck.
    Call me for details.
    Digital One, Inc.
    Kevin Hedin
    907-245-2669
  • Buddy Unidas
    March 28, 2006 at 8:44 pm
    Thanks guys! I appreciate ya’ll sharing the expert knowledge. Looks like it’s time to upgrade the studio….
    BUd
  • Ron James
    March 28, 2006 at 9:18 pm
    Bret, I just doublechecked my DSR-40 and there doesn’t appear to be any offset. Now I’m wondering, though, if I’m missing something.
    Do newer updates of the Keyspan software take this into account or this irrelevant?
  • Bret Williams
    March 29, 2006 at 4:35 am
    Don’t know. Just check it. Easiest way with beta is to capture a clip with bitc on. If you can’t do that, digitize a clip and check the timecode on an obvious frame like a cut point.
  • Ron James
    March 30, 2006 at 12:52 am
    Thanks, Bret.
    I did check it and it was dead on. But now I’m confused by LTC vs. VITC. When I created a Capture Preset for RS-422, the default was LTC and I left it like that and captured an hour tape on the DSR-40. The TC was dead on.
    Now I get a tape that is labelled with VITC, so I switched the setting in the preset and the clip was one frame off! There’s also a “LTC + VITC” setting available.
    Is this something that needs to be changed all the time? Most of the time I’m not even sure which it is b/c the tapes I’m given aren’t labelled with this info and I have no idea if there’s a way to detect which is present on the tape. I’m searching for answers, but if you have any advice, please let me know!
    Cheers,
    James
