Activity › Forums › Apple Final Cut Pro Legacy › Capturing SP to Final Cut
  • Capturing SP to Final Cut
    Posted by John Gamble on January 27, 2010 at 2:03 pm
    I am having a problem with my Beta SP machine capturing into Final Cut 6,
    We can dump out fine, but when it comes to capture there is no picture and no audio. I have set everything to the correct settings in terms of capture etc.
    But I think it might be our black magic card. We have a Decklink HD Extreme.
    Everything in the card is set to Blackmagic 8 bit NTSC/PAL – with PAL preferences set to PAL.
    Everything in FCP is set to Pal 8-bit uncompressed – any suggestions would be greatly appreciated
    Ciao
    John
    Mark Spano replied 16 years, 8 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    January 27, 2010 at 4:25 pm
    Trash your preferences for FCP… Then use the easy setup for 8 bit uncompressed SD that should be there supplied by the drivers for the blackmagic card.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • John Gamble
    January 27, 2010 at 9:38 pm
    Hi Jerry,
    Thanks for the response. The last time I was in this situation was a long time ago, I remember being able to find preferences in the documents/final cut documents files. But that was on final Cut 4 or 5 I think. Where do I find the preferences on FCP 6, because FCP documents just has things about English – Japanese etc, showing my lack of practice I know???
    John
  • Mark Spano
    January 28, 2010 at 5:12 pm
    Preference Manager is your friend…
