Activity Forums Apple Final Cut Pro Legacy Capturing, seeing the “dropped frames”
  • Capturing, seeing the “dropped frames”
    Posted by Kevin C. on September 10, 2007 at 9:10 pm
    I finally got capturing down well. FCE 3.0
    But I did see that it kept quiting and saying aquisition completed, dropped frames.
    I finally unchecked the preference to stop capturing on dropped frames, and was able to continue. This tape was a test tape that was recorded over, maybe once before at most. Was this the issue? or something else? thanks!
    Kevin C. replied 19 years ago 2 Members · 2 Replies
  • Todd Gillespie
    September 11, 2007 at 4:32 am
    It sounds like there are timecode breaks on your tape-meaning that the recording was stopped and started again and there’s a slight gap between the stop and start.
    Or you’ve re-recorded over the tape with different timecode numbers.
    Neither is good for digitizing.
    Good Luck,
    Todd at UCSB
    Television Production
  • Kevin C.
    September 12, 2007 at 1:02 am
    wow, that’s it? tape did have something below it, just one thing. but that could throw it off like that?
