Activity Forums Avid Media Composer Capturing sd in an HD project with MC 5.51
  • Capturing sd in an HD project with MC 5.51
    Posted by Mickey Grant on May 10, 2011 at 3:44 am
    I’ve done everything it says in DV Scene Extraction but I keep getting message “Exception: Audio/Video is unexpectedly no longer coming into the system” message shortly after I hit record.
    HELP!!!
    Mac Pro 2.8 Ghz Quad Core Intel Xeon Processor with 8Gigs of ram,
    Dan Marlow replied 15 years, 3 months ago 3 Members · 4 Replies
  • John Pale
    May 10, 2011 at 4:40 am
    Have you tried switching your project temporarily to SD to perform the capture?
  • Mickey Grant
    May 10, 2011 at 4:46 am
    Then what would I do? Import it?
  • Mickey Grant
    May 10, 2011 at 1:13 pm
    It captures fine into an SD project. With MC 5.51 is it then possible to import it into a HD project?
    As I indicated, in my HD project I think I’ve done everything right in the settings to capture it. Is it because it’s drop frame?
  • Dan Marlow
    May 11, 2011 at 12:48 pm
    All you should need to do is switch the format tab to SD, Capture at your chosen SD resolution, then switch the project back to HD.
    Do this all in the same project.
