Activity › Forums › Adobe Premiere Pro › Capturing problems
  • Capturing problems
    Posted by Bruce Rutland on February 27, 2006 at 10:51 pm
    Hi everyone.
    I’ve just installed A ‘Matrox RTX 100 Xtreme’ card.
    I now seem to only be able to capture a very short amount of video, anything from one second to 6 seconds. In the capture window it says ‘paused’. I did not instruct this to happen, then it comes up with ‘Unknown recorder error’. and then the option to save ‘captured clip’ and change the name if required comes up.
    Don’t know if it’s the card or something in the preferences within ‘PremierePro’ that’s the problem.
    Has anyone had the same problem or does anyone knows a solution?
    Hope someone can help me.
    Many thanks in advance.
    Bruce.
    Aanarav Sareen replied 20 years, 7 months ago 2 Members · 1 Reply
  • Aanarav Sareen
    February 27, 2006 at 11:00 pm
    More than likely, it is the card that is causing the problems. Did you follow the instructions step by step? Also see if the card manufacturer has an update posted on their site.
