Activity Forums AJA Video Systems Capturing problems with FCP + AJA io
  • Capturing problems with FCP + AJA io
    Posted by Dez Loreen on May 9, 2005 at 4:44 pm
    Can’t really capture any footage off the DV deck thru the AJA io.
    Our video feed is S-Video, XLR analog audio.
    When we try to ‘capture now’ with FCP, there are pop up messages that say that I should check the VTR, and there was a tape error. I tried a few tapes, and got the same message.
    any help with this would be great.
    thx, Dez
    “Trying is the first step towards failure.”
    -Homer J. Simpson
    Lee Berger replied 21 years, 4 months ago 2 Members · 3 Replies
  • Lee Berger
    May 9, 2005 at 5:29 pm
    Hi:
    If you’re using Capture Now I would assume that you don’t have any way to control your VTR via RS-422. If so FCP is waiting to communicate with your VTR via RS-422 control and can’t. Simply open the Capture Tool and select the Capture Settings Tab, Select the Device Control drop down and select Non-Controllable Device. After you select capture now, you will need to press Play on your VTR.
    Lee
  • Lee Berger
    Hi:
    Lee
  • Lee Berger
    May 9, 2005 at 5:30 pm
    Hi:
    Lee
