Capturing problems “Problems reading tape”
Hi guys,
I have a problem capturing some DV-PAL footage in FCP 5. I’m using a Sony DCR-PC120E camcoder.
Whenever I try to capture “now”, a clip or a batch, this error occurs after 1-10 seconds.“Capture encountered a problem reading the data on your source tape. This could be due to a problem with the tape. To capture as much of your footage as possible please capture a clip that ends before this segment, and another one that starts right after it.”
I have two tapes with the same problem. It doesn’t occur on the same timecodes every time, so I’m almost certain that it’s not the tape that is the problem. I’m thinking a setting-issue in FCP. I’ve tried different capture presets and settings, but I’m kinda lost…
Anybody know what the problem is?
