Activity Forums Apple Final Cut Pro Legacy Capturing Problem with 23.98 Drop Frame vs. Non-Drop Frame??
  • Capturing Problem with 23.98 Drop Frame vs. Non-Drop Frame??
    Posted by Ted Passon on November 22, 2008 at 2:34 am
    I’m editing on Final Cut 6.0 and trying to batch capture footage using a JVC BR-DV6000 deck. I’m pulling in footage that was shot 24pA (23.98) from an HVX-200. My capture setting is “DV NTSC Advanced (2:3:3:2) Pulldown Removal”. Whenever I try to Batch I’m getting this crazy message that says, “WARNING: You are about to capture Non-Drop Frame Media from a device currently detecting Drop Frame Media. If you proceed you may experience problems…”
    If I hit continue the capture does not work.
    I don’t understand what it’s asking me to do? I’ve never had to do anything involving settings for Drop or Non-Drop Frame in FCP.
    I found ways to set both the deck and Final Cut to Drop Frame or Non-Drop Frame and it doesn’t make a difference. I’ve never had this problem with 23.98 footage before. The only thing that’s changed is that I just had the deck serviced. The repair guy says he didn’t change anything but suggested it couldn’t hurt reverting to factory setting, which I did but no help.
    Any idea what could be causing this?
    Please HELP!
    Thanks so much!
    ted
    Drew Hudgins replied 17 years ago 4 Members · 5 Replies
  • Paul Katz
    December 28, 2008 at 9:40 pm
    I’m having the same problem!I’m getting that warning: you are about to capture NON-Drop Frame media from a device currently configured or detecting Drop-Frame media: Can you please tell me what you did to capture? I’m trying to capture 24Pa footage with a Canon camcorder as a deck.
    Paul
  • Gary Adcock
    December 29, 2008 at 1:15 pm
    [Paul Katz] “‘warning: you are about to capture NON-Drop Frame media from a device currently configured or detecting Drop-Frame media: Can you please tell me what you did to capture?”
    You are capturing 24p material (that is always Non-Drop) from 29.97 interlaced content that was recorded Drop Frame
    I you can override this issue with a deck – Since you do not mention camera model – I cannot answer whether you could or not with that camera.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Ted Passon
    December 29, 2008 at 3:12 pm
    Hi Gary,
    How can this issues be solved with a deck? I’m using a JVC BR-DV6000 DV/DVCAM deck. I found a setting to change it to Drop-frame or Non-Drop frame but it doesn’t seem to make much of a difference.
    Thanks for any help!
    best,
    ted
  • Paul Katz
    December 29, 2008 at 5:02 pm
    Hi Gary,
    Actually the warning said: “You are about to capture Drop Frame media from a device currently detecting or configured for Non-Dropmedia. The 24Pa footage was shot with a Canon XL2. I use a Canon camcorder as the deck to capture.this deck does not shoot 24p but should not make a difference in capturing…should it?
    What I did to capture is User Preferences:Timeline Options: UNchecked drop Frame. Also under Audio/Video settings: device control presets changed that to non Drop also. When I want to use 60i 29.97 footage I will have to change all the above back to drop frame..
    Cheers,
    Paul
  • Drew Hudgins
    September 14, 2009 at 7:06 pm
    Yep, I was just about to offer the same advice. I just changed the second of the things you suggested and it seemed to work. Oddly though, I shot 24p (not the Advanced Mode though) on the Panasonic DVX100b
    Oh yeah, I even checked the deck settings (the heads-dirty-all-the-time JVC BR-DV3000 model) and it checked out (DF … for DV)
    I shouldn’t be concerned about anything funky, should I ? Like weird audio or ANYTHING associated with the two not really matching (the “two” being FCP and the Deck).
    Drew
    Motivation is what gets you started. Habit is what keeps you going.
