Activity Forums Apple Final Cut Pro Legacy capturing problem
  • capturing problem
    Posted by Mirozake on October 31, 2007 at 6:27 pm
    I have a camera in vcr mode hooked up. I’m using latest Final Cut Pro. When I go to capture (now) it starts capturing for a few second and gives me this error message:
    “Capture encountered a problme reading your data on your source tape. This could be due to a problem with the tape. Capture has been aborted and your clip has been saved.”
    Just for more info, this is a tape I recorded over, and I didn’t reset the timecodes or anything. But I would think there’s gotta be a way to simply play the tape and capture, right?
    Any help much appreciated..
    Miro
    Neal Broffman replied 18 years, 10 months ago 2 Members · 2 Replies
  • Neal Broffman
    October 31, 2007 at 6:29 pm
    If you are going to use the Capture Now function, have you changed the capture settings tab to “uncontrollable device”? If not then change it and then hit capture now and then hit play manually on your camera/vcr.
    Neal Broffman
    One Production Place, Atlanta, GA
    In Production: “Road To Freedom”, a short documentary being produced for the High Museum of Art in Atlanta that will be shown as part of a major exhibition of vintage Civil Rights Movement photographs. Opens June 7, 2008.
  • Neal Broffman
    October 31, 2007 at 6:32 pm
    That, of course, would be non-controllable device…there are already enough uncontrollable devices running around out there.
    Neal Broffman
