Activity Forums Apple Final Cut Pro Legacy capturing problem
  • capturing problem
    Posted by Mark Fason on June 24, 2006 at 9:22 pm
    hey,
    i’m trying to capture dvcpro footage(not hd) with a 1200a deck. when i use the dv-ntsc easy set-up it won’t capture but when i use the offlineRT setting everything works fine. i was wondering if anyone had any ideas on the best way to capture at the highest resolution.
    thanks,
    mark
    David Roth weiss replied 20 years, 2 months ago 3 Members · 5 Replies
  • Bouncing Account needs new email address
    June 24, 2006 at 10:06 pm
    [Mark Fason] “when i use the dv-ntsc easy set-up it won’t capture”
    If it doesn’t Capture, what DOES it do?
    Blank image, flicker, stall?
    Have you restarted the Mac, TRASHED your FCP Preferences and repaired Disk permissions?
  • David Roth weiss
    June 24, 2006 at 10:30 pm
    Have you tried DV-50 easy setup which happens to be DVCPro???
  • Mark Fason
    June 24, 2006 at 10:34 pm
    matte,
    thanks for the response. during capture, fcp freezes on the first frame of the video and then a box titled ‘Insert Reel’ comes on the screen and says, ‘the reel #-00:00:00:00 – 0 clips – DONE’ and at the bottom of this window it says, ‘Capture encountered a problem reading the data on your source tape. This could be due to a problem with the tape. To capture as much of your footage as possible, please log and capture a clip that ends before this segment, and another one that starts right after it.’
    i don’t think there is a problem with the tape because fcp will capture it in the offlineRT easy set-up.
    i did trash preferences/rebuild permissions/shutdown-restart the computer.
    again, the footage is dvcpro(not hd) shot with an SDX900 and i’m trying to capture with the panasonic 1200a.
    any other help would be appreciated.
    mark
  • Mark Fason
    June 25, 2006 at 1:31 am
    thanks,
    though i couldn’t find a dv-50 easy set-up, using dv-50 in log and capture-capture settings-capture/input pulldown menu did the trick.
    mark
  • David Roth weiss
    June 25, 2006 at 5:36 am
    Mark,
    Next time check the little box that says “show all”… Thats where Apple has chosen to hide the strangely named DV-50 easy setup.
    Did you happen to notice that Apple named the PAL setup DVCPro50, while while the NTSC version is oddly named DV-50??? Odd that they wouldn’t just go ahead and change that in an update sometime, cuz you know they must know about it by now.
    DRW
