Activity › Forums › Adobe Premiere Pro › Capturing Problem
  • Capturing Problem
    Posted by Ramarie Swart on December 31, 2007 at 7:21 am
    Hello. This is my first time on this website. I have a rather sticky problem. One of my shooters shot a project in 30P (Canon XL2) instead of 60i, by accident. My capturing deck (Prosumer-Sony GV-D1000) seems to be having a problem with the progressive footage. There are pixels dancing all over the place. I thought it was my LCD screen and it would all render out, but it wasn’t the screen. The shooter was on vacation, so I couldn’t ask him at the time what he had shot in. I went ahead and completed the edit in the hopes that upon his return, if I re-capture the footage from his camera, the time code will line up and my editing project will be saved. Is there something I must do with the software to capture in Progressive mode? Also, after I re-capture the footage, what is the best way to ensure that the time code will line up, so I don’t have to do the edit all over again.
    Thanx.
    RaMarie
    Mike Velte replied 18 years, 9 months ago 2 Members · 1 Reply
  • Mike Velte
    December 31, 2007 at 5:41 pm
    [RaMarie Swart] “There are pixels dancing all over the place”
    This is hopefully just a play back issue with your deck and when captured with the shooter’s camera all will be well.
    [RaMarie Swart] “something I must do with the software to capture in Progressive mode?”
    Capturing is simply data transfer.
    [RaMarie Swart] “what is the best way to ensure that the time code will line up”
    You will manually need to synchronize both camera capture files once in the sequence by using a video or audio event like a still camera flash or hand clap or some other very short event.
    You might want to read about multicam editing in the Help files.
