Activity Forums Avid Media Composer Capturing PAL DV
  • Capturing PAL DV
    Posted by John Watts on July 29, 2009 at 8:27 pm
    I have successfully captured PAL DV 25i from our Sony DV Deck to MC 3.1 many times with no difficulty. But today, I have either forgotten something basic or have some sort of issue going on.
    So I’m creating a PAL 25i project. Have tried MXF and OMF, 1:1 and PAL dv. Digitizing directy (no mojo) into Avid. Picture has grey boxes (it’s not dirty heads, as I can see the deck on another monitor, image is fine) and audio does not capture at all. Yes, the deck and Avid are set at 48K. When I search the tape while capture window is open, I can hear the audio, but when played at correct speed, audio goes away? Playback of image from Avid also shows large grey squares with no audio.
    I can’t digitize analog, both due to low quality and the fact that our Mojo does nothing but lock up the edit system when hooked up.
    Hopefully I missing something basic here, because I’ve gotten past this before but now my brain is officially hurting.
    Thanks much if you’ve got an idea to try.
    John Watts
    John Watts replied 16 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
