Activity Forums Apple Final Cut Pro Legacy Capturing one clip but ending up with more
  • Capturing one clip but ending up with more
    Posted by Eric Bray on October 21, 2008 at 3:36 am
    Why when I capture a dv tape in its entirety, does it give me more than one clip? It’s capturing everything it’s supposed to so I guess I shouldn’t complain. I’m just wondering what’s happening here?
    Eric Bray replied 17 years, 11 months ago 3 Members · 3 Replies
  • Alan Smith
    October 21, 2008 at 2:24 pm
    [Eric Bray] “Why when I capture a dv tape in its entirety, does it give me more than one clip?”
    Check your User Preferences. There is an option for “On Timecode Break:” if that is set to Make New Clip, then each time FCP encounters a timecode break, it will make a new clip and keep digitizing.
    Alan
    Alan Smith
    Media317
    Check out my blog – https://media317.com
  • Nick Meyers
    October 21, 2008 at 3:03 pm
    2 possible causes:
    1. you have “limit capture / file size” ticked in your FCP system settings
    2. your drive is formatted MS DOS
    the first is not a huge problem, but you are asking for trouble, so best to turn it off.
    the second (wrongly formatted drive) IS a problem.
    you cant fix that without erasing all the media from it.
    so you’d have to copy all the media across to another drive before you re-format it.
    nick
  • Eric Bray
    October 21, 2008 at 3:33 pm
    Okay thanks, it was just some settings that needed changed.
