Activity Forums Apple Final Cut Pro Legacy Capturing on HVR-HD1000U
  • Michael Sacci
    August 18, 2008 at 6:13 am
    What type of trouble are you having.
    Using the correct Easy DV (NTSC, PAL Anamorphic, 23.98?) Set Up is normally all you need to do
  • Clinton Hornsby
    August 19, 2008 at 4:23 am
    Well I may be trying to do something you can’t but I would like to capture something I shot in 24f setting on a Canon XH-A1. Is this possible using the Sony HVR-HD1000u?
