Activity › Forums › VEGAS Pro › Capturing ok when importing but preview (in capture) screen is black
  • Capturing ok when importing but preview (in capture) screen is black
    Posted by Linda O’connell on September 13, 2013 at 9:05 pm
    I have a very old computer (Vista) that I just use for importing video. When I import (no matter if it’s from a firewire or ADVC Canupus) the video will show on the import preview screen.
    BUT as soon as I hit “Capture Video” the video disappears. When I hit stop, the video has imported correctly and everything is fine.
    When I import with Sony moviEZ it does the same thing.
    When I import with windows media it does show the video.
    This has been an outgoing problem. Any suggestions
    Linda O’connell replied 13 years ago 2 Members · 3 Replies
  • Graham Bernard
    September 14, 2013 at 6:12 am
    Linda, I’ve recently had this while needing to capture “old” VHS analogue. And yes, I had the “Always Allow Show Preview While Capturing” selected. I don’t have a remedy.
    Cheers
    Grazie
  • Linda O’connell
    September 14, 2013 at 2:10 pm
    That is exacatly what I was doing (transferring a VHS) but what is weird is it is happening when I use a firewire also. I used to use a different Vista computer and it worked fine. I am wondering if it’s some setting on the computer itself.
    Thanks anyway.
  • Linda O’connell
    October 3, 2013 at 12:16 am
    FOUND THE PROBLEM!
    I found on another forum to check the motherboard fire wire brand. Apparently, Texas Instruments & other brands have problems with Vegas. I bought another fire wire port online for $25 installed and perfect. It works. I now get the preview window.
    What is weird is the brand of fire wire I bought after market is also Texas Instruments (I didn’t know that when I bought it) and the after market works fine. So it must have something to do with the factory one.
