Activity Forums Apple Final Cut Pro Legacy capturing multiple betacam sources
  • capturing multiple betacam sources
    Posted by Nigel Askew on May 18, 2010 at 9:41 am
    Hi, this might not be right place to ask but I couldn’t find anywhere more appropriate, but basically, we have a lot of betacam tapes to capture, and we were wondering if there is a machine that will capture multiple betacam tapes at once to a hard drive, without the need to go through a capture program/pc/capture cards.
    let me know if i need to post this question somewhere else,
    thanks
    Arnie Schlissel replied 16 years, 3 months ago 3 Members · 2 Replies
  • Steve Eisen
    May 18, 2010 at 12:02 pm
    One machine, one tape, one capture. There is no faster solution.
    For best quality, if that’s important at all, you need to use a capture card/io box. ProRes would be the recommended format vs 8 bit uncompressed.
    I would farm this job out if you don’t have the necessary hardware.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Arnie Schlissel
    May 18, 2010 at 3:10 pm
    How many decks do you have? How many people do you have to run them? I suppose you could always buy more decks…
    At some point, someone needs to go through all the footage to break it down. IMO, this is best done by logging before digitizing. That way, you only digitize what’s useful and you only digitize it in the chunks that you’re going to use it in.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
