Activity Forums Avid Media Composer Capturing mix-rate clips problems
  • Capturing mix-rate clips problems
    Posted by Craig Hirshberg on December 4, 2009 at 4:23 pm
    Ugh. Here it goes.
    My assistant editors logged and captured mini DV footage into a 720p 23.976 project. About 12 tapes in total. Playback is obviously jerky and wonky looking.
    I created a 30i project and imported the bins, thinking I could just re-batch capture the footage correctly at 29.97 but get the following:
    “You cannot batch capture mix-rate clips. Please capture the individual clips in their respective project formats.”
    I tried Modify -> Set Format on both the clips and a sequence to no avail.
    Any ideas on how I can trick the Avid into thinking these clips are 29.97 (which, in reality, they already are)?
    Craig
    Craig Hirshberg replied 16 years, 9 months ago 4 Members · 4 Replies
  • Job Ter burg
    December 4, 2009 at 9:05 pm
    Export as ALE, modify ALE to 29.97, import ALE, batch capture?
  • Michael Phillips
    December 5, 2009 at 2:36 am
    The ALE method that Job suggested is the way to go.
    Michael
    Michael Phillips
  • Terence Curren
    December 5, 2009 at 7:07 am
    Or… were the originals shot 23.98? In which case, you need to have all clips start at a TC ending in :00 or :05. Otherwise you will get the phenomena you mentioned.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Craig Hirshberg
    December 11, 2009 at 4:35 pm
    Thank you for the responses! Sorry for the late reply, got caught up in a different project.
    I tried the ALE solution and it worked perfectly! Very clever!
