Activity › Forums › Apple Final Cut Pro Legacy › capturing locks up, says”locating timecode break” when there should be none.
  • capturing locks up, says”locating timecode break” when there should be none.
    Posted by Mr. Fiddle on September 29, 2006 at 8:53 pm
    i had a hi8 tape transfered to mini dv and while digitizing the dv, the capture window locks up and reads “locating timecode break” i let it go and eventually it puts a clip in the fcp browser and automatically begins creating a new one. i let it go for a while and thought the clips, when placed in a sequence would be seemless, but they are not. the breaks dont seem to coincide with anything. any ideas? much appreciated….
    Winston A. cely replied 19 years, 12 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    September 29, 2006 at 9:23 pm
    My try a clone of the tape (poor recording?) and rebuild the TC track that way. Clean the heads of the playback machine?
    You can always use non controllable device and capture now… but it won’t retain the correct timecode of course.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Winston A. cely
    September 29, 2006 at 10:18 pm
    What type of deck are you using? Can you view the TC on the deck? If so, check the dv tape by scrolling one frame at a time around where FCP says there’s a TC break.
    On a not too distantly related topic, we shot hours of footage on BetaSP, in a news broadcast studio (an affiliate of one of the big TV companies). We got the tapes back and were trying to capture them but were constantly getting TC breaks…. in what seemed to be a pattern. Turns out, the cameras and the actual recording decks were set differently. One to drop and one to non-drop. So no matter what we had bad TC. On top of that, our producer did a paper edit to TC window dubs of the tapes, so we were screwed if we wanted to just capture while ignoring breaks. We eventually did that, which meant twice as much edit time.
    The studio was super accommodating. Before we knew what the problem was they sent us one of the decks they had used, so that we could capture directly from it at no charge, and eventually a deal on billing was made (we had used more of their equipment than we said we would, and our shoot had gone long as well).
    Moral of the story is never assume something is going to be done right, even with professionals. No matter what systems are in place, there’s one major flaw in them all, humans.
    “If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
    Machine Model: Power Mac G5
    CPU Type: PowerPC G5 (3.0)
    Number Of CPUs: 2
    CPU Speed: 2.5 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 4.5 GB
    Final Cut Studio (Not Universal, yet)
