Activity › Forums › Blackmagic Design › capturing issues with blackMagic HD extreme card
  • capturing issues with blackMagic HD extreme card
    Posted by Venkat on October 27, 2007 at 7:30 am
    Hi..,
    I’m using Black Magic HD Extreme card to capture my varicam footage.
    Let me brief about my system.
    I have Mac Pro 3.0 GHz Machine
    with 5 GB ram &
    Caldigit S2VR HD DRIVE WITH 230MB/S Speed.
    & Black Magic HD Extreme card.
    I edit my footage @ 25p. I don’t have any problem when i’m capturing footage which has been shot at 25 fps. But whenever I try to capture my footage shot 60fps for slowmotion Im jus getting 40% of the footage that is if i capture a 1 minute clip, I’m just getting only 25 secs only.
    I can get something but not very clear. footage at the frame rate 60 & Im capuring it at 25 fps. So per minute i’m just getting 25 secs. I know the card the doing the required pull-down while capturing. How to get rid of this. But the required slow-motion is done without any problem.
    Help me out in this.
    Kristian Lam replied 18 years, 11 months ago 2 Members · 1 Reply
  • Kristian Lam
    October 31, 2007 at 6:35 am
    Are you capturing your footage shot at 60fps using the 720p25/60 setup? If so, this sounds normal. You will need to capture beyond the required time length of the clip in order to get the full 1 minute capture.
    regards
    Kristian Lam
    Blackmagic Design
