Activity Forums Adobe Premiere Pro Capturing in the background
  • Capturing in the background
    Posted by Robert Dulfer on July 22, 2012 at 6:47 pm
    I am going through the PP Basic tutorials now. Thought that, while doing that, I might as well start capturing a ton of miniDVs I have laying around, knowing that is a slow process.
    So basically work on the PC and listen and run tutorials while PP is capturing in the background. I ran into two problem trying that.
    1) I could not find a way how to shut of the sound of what PP is capturing. I want to capture the sound of the tape, but do not want to listen to hours of it while capturing. Any way how to do that WITHOUT switching off all sound? I still would like to listen to music or tutorials while capturing.
    2) The question might be moot while each time I switch to a different program and start typing, PP capturing jumps to “pause”. Is that normal?
    I tried to google these questions but a million unrelated posts came up whatever keywords I tried.
    Asus P8Z68-V Pro gen 3; i7-2600k; 16 GB RAM, ASUS-NVIDIA GTX 570, 240 GB SSD as OS and 1 TB WD as data drive, Coolmaster Silencio 550 silent case (I love it). Adobe Production Premiere CS 6
    Norman Greenwood replied 14 years ago 3 Members · 3 Replies
  • Ann Bens
    July 23, 2012 at 8:50 am
    1. you cannot turn off the sound.
    2. No that is not normal, but if you have tons of tapes to capture and you want them to be flawless. Dont do any else with the pc then capture.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Robert Dulfer
    July 23, 2012 at 8:52 pm
    thanks, I will just capture what I need and do some other work in the mean time
  • Norman Greenwood
    August 13, 2012 at 7:06 pm
    Ann is completely right, don’t do anything while capturing, it can cause many issues. I’ve made that mistake myself.
    However, you may be able to turn off the sound if you really want to do some tutorials. If you are running Windows (I am using Windows 7), you can click on the sound in the lower-right corner and you’ll see “Mixer”. Click on that and you will see your applications running (i.e. Firefox, PP, etc.). You can then turn off the sound for just PP while listening to other things. I have never tried it while capturing, but since it is using PP I can’t see why not.
