Activity Forums Apple Final Cut Pro Legacy Capturing in higher codec?
  • Capturing in higher codec?
    Posted by Nick Ryan on November 15, 2005 at 8:06 pm
    I hate to ask such a dumb question…
    If I need to add a DV clip to an uncompressed sequence that I’m working on, can I just capture that DV footage @ uncompressed to save render time while I’m fine-tuning it on the timeline? Can I just firewire capture the DV like normal only change the capture preset to 8-bit uncompressed? Or will this cause a collision of codecs? I realize capturing at the higher codec doesn’t improve my quality any – its just for the sake of efficiency in the timeline.
    Nick
    Alexander Feichter replied 20 years, 9 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    November 15, 2005 at 9:00 pm
    No, FCP will not transcode your dv footage to 8 bit over firewire.
    Take this footage out to After Effects and render it there. You will get the best software results from AE, unless you have shake.
    Compressor 2 will do a pretty nice job as well. Start the 8 bit NTSC or PAL advanced format conversion preset.
  • Alexander Feichter
    November 15, 2005 at 10:15 pm
    within fc you could do it this way:
    put your DV-material into a new sequence that has the same settings as your destination timeline.
    render the new sequence and use it as a nested clip instead.
    after putting the nested seq. to your timeline open it’s properties and set the alpha to ignore and adjust eventually the field order.
    greetings
    alex
