Activity › Forums › Apple Final Cut Pro Legacy › Capturing HDV with MacBook Pro
Posted by Jim Edds on February 5, 2010 at 9:06 pmI’m in the stock footage business. A lot of my clients are requesting Quicktime files with a prores codec. If I get a 17 in macbook pro, can I capture HDV from a Sony Z1 (connected via a 4pin FW400 to FW800 9 pin port) to a separate esata drive hooked up to the expresscard slot? And what is the min. drive configuration needed to capture to work in the prores 422 HQ codec? USB2, FW400, FW800, ESata? Thanks!
John Fishbackreplied 15 years, 7 months ago 4 Members · 7 Replies
Rob Grauert
February 6, 2010 at 5:06 amHere is an article on capturing HDV as ProRes:
https://library.creativecow.net/articles/poisson_chris/hdv-prores.php
Also, you only need capture your HDV as ProRes because HDV is 8-bit. You will gain nothing by capturing as ProRes HQ. HQ is ideal for 10-bit sources larger than 1920X1080.
Now, I’ve never captured HDV as ProRes, but I think you will be fine capturing through FW800 to one of those G-Tech G-RAIDs that are set up for RAID 0
Robert J. Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com -
John Fishback
February 6, 2010 at 7:16 pmFYI, all ProRes codecs are 10-bit. Check it out in Apple’s ProRes Whitepaper It’s an interesting read.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Jim Edds
February 6, 2010 at 7:33 pmThanks for the link. I read the article but my main concern is proper setup to capture from the cam to an external hard drive connected to the laptop.
The HDV cam will be connected to the firewire 800 port on the laptop. It is ok then to connect an Esata drive to the express card slot with an express card esata adapter? I don’t want to connect the HDV cam to the hard drive and then to the FW800 port. I’m coming over from the PC world so I just need to make sure the hardware will work. Thanks!
Zane Barker
February 6, 2010 at 8:04 pm[Jim Edds] “The HDV cam will be connected to the firewire 800 port on the laptop. It is ok then to connect an Esata drive to the express card slot with an express card esata adapter?”
That is PERFECT I do it all the time.
Hindsight is always 1080p
Jim Edds
February 6, 2010 at 9:27 pmExcellent, thanks everyone for your posts. I’ll place my order for a Macbook Pro and FCP Monday. Watch after I order, Apple will introduce Quad Macbook Pros!
Jim Edds
February 24, 2011 at 7:42 pmI applied the timecode generator to a 1 hr. clip on the timeline. Works great. However, when I cut the clip up it wants to zero out and start counting again at the beginning of each clip. Is there any way to avoid this?
MBP I7 2.66, 8GB RAM, 120GB SSD, FCS 3, OS 10.6.4, 27in Apple Cinema display, G-Raid 4TB Raid 0, Sonnet Tempo Express Card
ExtremeStorms.com
John Fishback
February 24, 2011 at 10:08 pmTry using the Timecode Reader filter instead of the Generator. It will show you the source timecode of the clip.
John
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
