Activity › Forums › VEGAS Pro › capturing HDV using the hvr-m10u deck
  • capturing HDV using the hvr-m10u deck
    Posted by Niklas on June 3, 2005 at 6:54 pm
    I ve been trying to capture hdv clips using vegas 6.0 with the hvr-m10u deck. I ve done exactly what they are explaining in the help index in the software, but it won t recognize the device. Are there any tricks i should know about?
    thanks
    Nic
    Jeffrey F. krepner replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jeffrey F. krepner
    June 3, 2005 at 8:54 pm
    Nic, does Windows recognize it? I think on XP you can go to control panel and under imaging devices you should see something when the deck is turned on and plugged in… also my system “chimes” when I plug in a new device.
    If so, make sure you have device control enabled in Vegas under preferences.
    jeff
