Activity Forums Apple Final Cut Pro Legacy Capturing HDV to Apple Prores422 problems
  • Capturing HDV to Apple Prores422 problems
    Posted by Hannah Gibson on October 6, 2009 at 8:35 am
    Hi guys,
    I have been hunting around the web and these forums but can’t quite find a solution to my problem.
    Basically I can’t seem to log and Capture my HDV footage shot at 1080i50 to Apple ProRes.
    In the Audio/Video set up I have put
    Sequence Preset: Apple ProRes 422 1440 *1080 50i
    Capture preset: HDV Apple Proress 422
    Sony HDV 1080i50 FireWire
    I have changed a few things round a bit but the same error keeps popping up which is:
    “To capture HDV source material, both the capture and Device control presets must be configured for HDV; otherwise to capture in another format both must not be configured for HDV.”
    This is Final cut version 6.0
    I have capturing form an HV20 although footage was shot on a sony z1. and i am not using any capture cards just my laptop and external HD firewire800.
    Any help is much appreciated as I don’t know much about this stuff, Just that capturing and exporting in HDV was not looking so good.
    Michael Gissing replied 16 years, 11 months ago 8 Members · 9 Replies
  • 9 Replies
  • Curious Turtle
    October 6, 2009 at 9:11 am
    When you say Final Cut V6 do you mean V6.05? Grab the updates from Apple’s site.
    Your Audio/Video capture settings sound as if it should work fine:
    Capture Preset: HDV-Apple ProRes 422
    Have you tried to use another device control preset? HDV Firewire Basic for example.
    All the best,
    Ben
    Curious Turtle Pro Video
    Training | Editing | Support
    Out Now – Film Wash Color Effects Vol. 3
    for After Effects & Apple Color
  • Hannah Gibson
    October 6, 2009 at 10:15 am
    yeah i have tried all the other capture presets too. I can’t figure it out, it won’t log and capture under any of them. not sure what’s going on. the only way it will work if if i set them all the HDV1080i50 only.
    Thinking of just upgrading to final cut 7 maybe.
    i just wanted to keep it at this version because it’s what all the computers at uni are running.
    thanks
  • Rafael Amador
    October 6, 2009 at 10:53 am
    Hi Hanna,
    i can not give you any tip because I don’t work with HDV, but probably the answer is in this tutorial of our COW leader Chris Poisson:
    https://library.creativecow.net/articles/poisson_chris/hdv-prores.php
    Best,
    rafael
    http://www.nagavideo.com
  • Arnie Schlissel
    October 6, 2009 at 11:50 am
    You have to use firewire HDV deck control to use the HDV to ProRes preset.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Stewart Charles
    October 6, 2009 at 12:10 pm
    when I tryed it I was told it is not possible to log and capture proress over fire wire.
    http://www.thin-kingmedia.co.uk
  • Arnie Schlissel
    October 6, 2009 at 1:19 pm
    [stewart charles] “when I tryed it I was told it is not possible to log and capture proress over fire wire.”
    That’s correct. Drives me nuts.
    If you want to be able to properly log your HDV tapes, you need to use a deck with RS-422 serial control and SDI or HDMI output and connect it to a capture card with SDI or HDMI input.
    Arnie
  • Ron Craig
    October 6, 2009 at 3:55 pm
    Well, that’s not the only way to “properly” do it. My way is similar but not exactly the same. I use a small Sony clamshell HDV deck with component out. I convert the component signal to SDI with an AJA mini-converter and import that signal to FCP through an AJA Kona 3 card. Machine control is via firewire, not RS-422. Log and capture with timecode.
  • David Roth weiss
    October 6, 2009 at 4:07 pm
    [stewart charles] “when I tryed it I was told it is not possible to log and capture proress over fire wire. “
    You don’t use log and capture…
    You must read the tutorial Rafael mentioned above at https://library.creativecow.net/articles/poisson_chris/hdv-prores.php to see how it’s done.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Michael Gissing
    October 6, 2009 at 9:22 pm
    [David Roth Weiss] “[stewart charles] “when I tryed it I was told it is not possible to log and capture proress over fire wire. ”
    You don’t use log and capture…”
    Confusing. Chris’s article says to open the log & capture window, but you have to read down the comments to find the clue that it isn’t a batch capture process but a capture now.
    Perhaps that is the problem for those that have struggled with this setup. Go to the bottom of the comments and work up.
