Activity › Forums › Apple Final Cut Pro Legacy › Capturing HDV 720p
  • Capturing HDV 720p
    Posted by Banicma on December 13, 2006 at 4:58 pm
    I have HDV footage shot with a JVC GY-HD100U @720p
    I’m trying to capturing it using the Sony HVR-M25U.
    The footage plays in the deck just fine but when i try to capture it via firewire FCP can’t recognize the information on the tape.
    Is there an Easy Setup configuration i should be using specific to using the HVR deck?
    I’ve heard that the deck can’t capture @ 720p. is this true?
    Do i have to down convert from HDV to DV?
    Shane Ross replied 19 years, 9 months ago 2 Members · 1 Reply
  • Shane Ross
    December 13, 2006 at 6:06 pm
    HDV formats will not play on other decks. JVC will not work on a Sony, Canon will not work on JVC…etc. YOu are going to need to get the JVC deck or use the JVC camera.
    Shane
    FCP Preferences set to UNCONTROLLED ADVICE
    Littlefrog Post
    http://www.lfhd.net
