Activity › Forums › Apple Final Cut Pro Legacy › capturing hdv 1080p
  • capturing hdv 1080p
    Posted by Ben Kaplan on April 21, 2008 at 8:07 pm
    Hello,
    Im trying to capture HDV 1080p30 via firewire (I didn’t even know you could shoot progressive HDV at 1080) and Im having trouble setting up the capture settings. I don’t seem to be able to change the frame rate and field dominance. I can’t edit the pre-existing HDV settings because they’re locked. Is there a way to unlock these or create a custom HDV capture setting from scratch. And this is not my project, so although I’m aware of the alternative workflow options, thats not my call on this one. Also, how horrible would it be if I just digitized the footage at 1080i60? Thanks for your time, much appreciated.
    BenK
    Jerry Hofmann replied 18 years, 5 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    April 21, 2008 at 9:39 pm
    Sure, duplicate one of these locked sequences in the sequence settings tab… it opens all ready for you to tweak!
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
