Activity › Forums › Apple Final Cut Pro Legacy › capturing HD in Final Cut Studio2
  • capturing HD in Final Cut Studio2
    Posted by Lana Banana on August 2, 2007 at 3:08 am
    Hi there, I’m new to working with HD footage and I’m stuck on the basics. Can someone give me some tips on how to capture footage that was shot on dvcam in HD mode? I’ve tried every setting possible but i’m not getting any picture through? I’ve also tried capturing it as SD and then recompressing via Media Manager using Pro Res to get HD files but keep getting an error message. If anyone has any tips then that would be great.
    thanks
    Lana
    (australia – so I’m using PAl)
    Stuart Simpson replied 19 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Jeff Carpenter
    August 2, 2007 at 3:45 am
    There’s no such thing as HD DVCAM. It’s an SD only format.
    I suppose it could be possible to record HDV onto a DVCAM tape, however. Is that what you have? If so, what camera recorded it and what are you using to play the footage back now?
    Capturing HD as SD is fine if you only want to work with SD, but that’s all you’ll ever have. There’s no way to turn it back into HD footage by converting it. If you want HD we’ll have to figure out how to capture it as HD.
    You’ll have to tell us what camera and deck (or camera for playback) you’re using (and how it’s connected to the computer) for us to give any more meaningful help.
  • Lana Banana
    August 2, 2007 at 4:10 am
    Thanks Jeff, the tapes are HD Dvcam tapes recorded in HD mode. The camera used to shoot with was a Sony Z1P and i’m capturing the footage into fcp using a Sony Digital HD Deck via firewire. failing that i could use the same camera we recorded on to capture with.
    thanks for your help
    Lana
  • David Roth weiss
    August 2, 2007 at 4:20 am
    [lana banana] “The camera used to shoot with was a Sony Z1P”
    The format the Z1 cameras shoot is called HDV. There is no such format as HD DVCAM. The Easy Setup you should choose would be HDV 1080i50.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Lana Banana
    August 2, 2007 at 4:24 am
    thanks David, I have already tried that but still no picture.
    Cheers
    Lana
  • Lana Banana
    August 2, 2007 at 4:50 am
    I’ve hooked up the camera and have managed to get pictures going into fcp that way. thanks guys…. but now when I capture, its capturing only a few minutes at a time instead of capturing the whole tape? The weird thing is, the capture doesnt abort every time a new file name is created, the only reason i discovered all the different file names was because i was testing to see if we had audio coming through. Any ideas on why its doing that?
  • John Pale
    August 2, 2007 at 5:06 am
    This is normal for HDV.
    Because of the nature of the compression it uses, it is necessary to make a new clip each time the camera is stopped.
  • Stuart Simpson
    August 2, 2007 at 1:17 pm
    There’s an option in the Log and Capture window which says something like “create new clip on start/stop detection”
    Make sure that is not ticked and you’ll get one long clip (providing you have no TC breaks)
    -Simmie
    2 G5 – Kona LH
    3 G4s – Cinewave
    1 xbox360, 1 PSP, 1 PS2 & a Gamecube
    https://www.speak.co.uk
