Activity › Forums › Apple Final Cut Pro Legacy › Capturing HD
  • Posted by Jason Elliott on May 4, 2006 at 11:23 pm
    Is there a way to capture HD footage without using a Panisonic codec of anykind? I can’t use DVCPro or Panisonic HD, for techniqal purposes. Would I be able to capture HD Varicam stuff with a Kona Uncompressed codec? The footage needs to be uncompressed.
    Gary Adcock replied 20 years, 5 months ago 3 Members · 2 Replies
  • Michael Gissing
    May 5, 2006 at 2:18 am
    Capture cards with HD SDI inputs can accept uncompressed HD from any machine with an HD SDI output – Panasonic, Sony etc. I assume Kona have such an interface card. I use Blackmagic HD extreme card and capture from Panasonic Pro100 and Sony HDCam machines straight to HD 10bit 4.2.2 uncompressed.
  • Gary Adcock
    May 5, 2006 at 1:31 pm
    [Jelliott] “Would I be able to capture HD Varicam stuff with a Kona Uncompressed codec? The footage needs to be uncompressed.”
    As Michael said
    with your Kona card, the possibilities for capture are only limited by your system, so Yes you should not have any problems capturing to 10bit 4:2:2 from any source in SD or HD.
    remember that to capture data in such copious amounts you will need very fast and very large storage arrays– this is NOT something that can be done over FW.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
    gary@studio37.com
