Activity › Forums › AJA Video Systems › Capturing Gameplay
Capturing Gameplay
Posted by Sukaafeisu on August 4, 2007 at 3:47 pmHi. I need some advice on what hardware to use.
I want to capture gameplay footage from PC games to create videos. I do not want to use FRAPS because I don’t feel it can handle the resolution I want to capture. I would like to be able to capture video at 1900×1200.
Most video cards now days have dual DVI, so I was wondering is there a capture card that takes DVI ? This way I could have 2 computers, 1 playing the game and the 2nd capturing.Daniel Miller replied 19 years, 1 month ago 5 Members · 7 Replies -
Bob Zelin
August 4, 2007 at 7:13 pmthere are numerous ways to do this, but you MUST SPEND MONEY. Most games have analog Y Pb Pr HD outputs. You can purchase an AJA HD10AVA, or AJA HD10A, and convert the analog game signal into HD-SDI, to capture into your Kona 3 card. If it is a true 1080i or 720p signal coming out of the game, you can take the Y Pb Pr signal out of the game, and go directly into the Y Pb Pr input of a Kona LHe card.
This is a better solution than getting a DVI breakout.
Bob Zelin
Bob Zelin
August 4, 2007 at 8:00 pmGefen and Doremi Labs make DVI to HD-SDI converters, that can go into your Kona LHe or Kona 3 card.
Bob Zelin
Sukaafeisu
August 5, 2007 at 5:03 pmGreat! thanks for your reply mate. going to have a look at this.
though I am not sure what you meant by this:
“Most games have analog Y Pb Pr HD outputs.”
I’m probably not knowledgeable enough to understand that. Did you mean most video cards have analog Y Pb Pr HD outputs? Or did you mean most game engines have options for analog Y Pb Pr HD outputs? -
Arnie Schlissel
August 5, 2007 at 5:42 pmI think that Bob was referring to set-top game boxes, like X-box or Playstation. Most computer graphics cards do not have any kind of video output.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Bob Zelin
August 5, 2007 at 7:37 pmArnie is correct. All video games that you can make a living with rely on XBox, XBox 360, Playstation, etc. that have analog component outputs on them. If you have a video game that is just software, and plays on your PC, there is ABSOLUTELY NO ASSURANCE that this will output to a standard video rate (be it SD or HD), and you can make NO ASSUMPTIONS that you can capture this on ANY capture card (AJA, Blackmagic, etc), unless you go thru a box like a Folsom, YEM, Spectrum, etc (these are really expensive).
Moral – ASSUME NOTHING .
Bob Zelin
Nick Righton
August 8, 2007 at 4:38 pmMiranda makes this box that will convert DVI to HD-SDI in the appropriate format for video. It costs about 4500 though.
https://www.bhphotovideo.com/c/product/441681-REG/Miranda_DVIRAMP2_DVI_RAMP2_DVI_to_HD_SDI.html
Daniel Miller
August 16, 2007 at 6:00 pmhey man,
Im doing the same thing. check out this thread.
https://forums.creativecow.net/readpost/98/866016?pview=t#head
hope that helps some.
