Activity › Forums › VEGAS Pro › Capturing from VCR?
  • Capturing from VCR?
    Posted by Eric Simon on August 9, 2007 at 3:57 am
    I know that you can capture from a camera but is it possible to capture from a VCR? I want to edit and burn some of my old video tapes as DVD.s Also if it is possible do I need any special hardware or upgrade to my video card? I have a nvidia geforce 4 ti 4600. Someone had suggested I get pinnacles dazzle but ive read bad reviews online and I hope Vegas can do what I need to do. Thanks
    Edward Troxel replied 19 years, 1 month ago 2 Members · 3 Replies
  • Edward Troxel
    August 9, 2007 at 12:30 pm
    Here’s how I do it:
    VCR -> analog -> camera/deck/convertor -> firewire -> computer
    Make sure “Device Control” is turned off in the capture program, start capturing, and then press Play on the VCR.
    Your camera has to have “pass-thru” capability to do this (most do) and you may have to change a menu setting in the camera.
    If you want to look at a convertor, look at the Canopus ADVC series or the ADS Pyro.
    Edward Troxel
    JETDV Scripts
  • Eric Simon
    August 9, 2007 at 5:40 pm
    Thank you so much. One problem though. I dont have a camera. I used someone elses to shoot the film and I dont have access to it at the moment. Anyway to just connect the computer to the vcr? I assume thats what the convertor would be for?
  • Edward Troxel
    August 10, 2007 at 3:39 pm
    Do check out the convertors I mentioned. That’s your best method.
    Edward Troxel
    JETDV Scripts
