Activity Forums Apple Final Cut Pro Legacy Capturing from Sony J-30SDI
  • Capturing from Sony J-30SDI
    Posted by Andrew Van baal on May 17, 2006 at 7:45 pm
    Hey everyone,
    I’m trying to capture footage from digibeta tapes in FCP 5 using the Sony J-30 deck’s Firewire output. I can’t get the video or audio to show up but I can control the deck from FCP. The Firewire output is going straight into my computer and all my settings are at DV NTSC. What am I doing wrong?
    – AvB
    AvB
    FCP Editor
    Mark Raudonis replied 20 years, 3 months ago 3 Members · 2 Replies
  • Walter Biscardi
    May 17, 2006 at 10:06 pm
    Is there a menu setting to send the video to Firewire on the deck? Sony is famous for placing switches or menu settings to change outputs or inputs.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Mark Raudonis
    May 18, 2006 at 3:19 am
    -AvB,
    Walter’s correct. It’s probably a menu function. But here’s some questions for you that will help us troubleshoot your problem.
    Have you ever used this deck before? Did it work? Do you have a user’s manual for the deck? Do you know how to access the menu?
    Do you have the J-30 connected to an external NTSC monitor to confirm that it’s working?
    Are you positive that your firewire cable is good?
    What are your digitize settings?
    There’s a million things that it could be. That’s why tech support costs so much!
    mark
