Activity Forums Apple Final Cut Pro Legacy capturing from sony dsr 2000a
  • capturing from sony dsr 2000a
    Posted by jon ching on April 14, 2024 at 7:13 pm
    Is there a FCP version that works with this deck? FCP 5 does not recognize it and “non-controllable device” is selected. FCP X does not continuously import and stops at the end of each clip so “import” has to be pushed constantly. Or is there a setting on the deck that needs to be selected?
    Thanks, Jon
    jon ching replied 2 years, 2 months ago 2 Members · 2 Replies
  • Ben Balser
    May 1, 2024 at 1:33 pm
    FCP and FCPX rely on timecode from the tape you’re digitizing. The problem is DV tape was always notorious for timecode drop-outs. Any drop-out and FCP/FCPX starts a new clip. Capture using QuickTime Player, it doesn’t care about timecode, and just captures like you’d expect.
  • jon ching
    May 25, 2024 at 8:29 pm
    Yes, that’s what I ended up doing. Thanks for the response.
