Activity Forums Apple Final Cut Pro Legacy Capturing from JVC Video Player to Final Cut Pro
  • Neil Patience
    April 20, 2012 at 9:12 pm
    I think that deck has firewire or compnent viceo out.
    The easiest way is to use the firewire (iLink) output and capture in the relevent dv format.
    If you have a video I/O card that accepts a component input, like an AJA LHE for example, you could connect via that.
    best wishes
    Neil
    http://www.patience.tv
