Activity Forums Apple Final Cut Pro Legacy Capturing from HD, sony HVR V1U HDV
  • Capturing from HD, sony HVR V1U HDV
    Posted by Andy Kachor on August 13, 2007 at 2:40 am
    I am using a powerbook G4, and I need to import from a sony HVR V1U HDV
    > 1080i.
    > Do you know how I import into Final cut 4.5–or do I need to import to
    > imovie HD? Importing into the regular imovie is working at 1/8 or 1/4
    > of the
    > regular speed!
    > Also, any particular settings for final cut pro you advise I use for the
    > edits?
    > THANK YOU so much! I appreciate any advice or tips!
    Mark Maness replied 19 years, 1 month ago 5 Members · 4 Replies
  • 13 Create COW Profile Image
    13
    August 13, 2007 at 4:19 am
    You will need a newer version of FCP to work with HDV.
  • Nycgrlll
    August 13, 2007 at 4:42 am
    I am using the HD version of FCP 4.5… Will this still not work?
  • Alfred Guzzetti
    August 13, 2007 at 12:12 pm
    4.5 won’t do HDV.
    Alfred Guzzetti
    Mac Pro Quad 2.66GHz 4GB RAM
    Intensity Pro card
    OS 10.4.9
    FCP 6.0
  • Mark Maness
    August 13, 2007 at 12:46 pm
    Support for the V1U came with FCP 6. And that’s still a little questionable. There is still problems with 24p support in FCP6. But as for HDV in general, FCP 5 gave full support for this.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
